DEVELOPERS FORUM - aras date field value is stoed less than one day in sql
rrt - Monday, November 7, 2016 3:44 AM:
i have date field on item form
i select date 07/06/2016
but it store as 07/05/2016 in sql
Yoann Maingon - Monday, November 7, 2016 4:42 AM:
Can you precise the datetime selected (including hours and miuntes) and the one shown?
Aras uses UTC as a neutral datetime. So depending on the moment of the day you set the date, the UTC can be different
You can run a conversion like this :
this.getInnovator().getI18NSessionContext().ConvertFromNeutral(DATE,"yyyy-MM-ddTHH:mm:ss");
rrt - Monday, November 7, 2016 5:07 AM:
hii Yoann Maingon
i take one field which data source is data and pattern is shortdate
i want to show date as mm-dd-yyyy on form but save correctly in sql
but it save one day less in sql database
as per your solution
where to write above code in form load or other event
Yoann Maingon - Monday, November 7, 2016 5:22 AM:
Why do you care about the SQL date? it is saved correctly with a neutral date that's it.
Give us a clear example of a datetime selected and how it appears in SQL.
rrt - Monday, November 7, 2016 6:03 AM:
as i fetch data from sql for ssrs report
in ssrs report date is come from sql
suppose i select date as following
in above picture i select date 10-25-2016 no matter of date format
as 10 -is month
25-is date
as in sql day is 24  (no matter of date format)
Yoann Maingon - Monday, November 7, 2016 7:55 AM:
When you select the date a time shows up. (I think usually, whatever the date it takes the time (HH:MM:SS) of the actual moment you select the date.)
Can you tell me which time it is?
rrt - Tuesday, November 8, 2016 1:39 AM:
its my system time when i select date
but problem with date
Yoann Maingon - Tuesday, November 8, 2016 2:18 AM:
what I need is the date you entered and the date you see in SQL
both as DD/MM/YYYY hh:mm:ss So I can tell the precise difference
rrt - Tuesday, November 8, 2016 2:33 AM:
as date field pattern is short date so it look like mm-dd-yyyy in aras form   , date is 10-25-2016
and in sql it look as yyyy-mm-dd hh:mm:ss  ,  date is 2016-24-10 18:30:00:00
when aras item save , date i entered 10-25-2016 (as see on aras form due to short date pattern) in form
is save in sql with one day less than selected date
Yoann Maingon - Tuesday, November 8, 2016 2:41 AM:
and the datetime time in sql is always 18:30?
rrt - Tuesday, November 8, 2016 3:19 AM:
yes it remain 18:30:00
as my field pattern is shortdate i cannot pick time for it
