DEVELOPERS FORUM - Passing a ID from a Form to a Method
didonato - Thursday, November 3, 2016 3:50 PM:
I'm trying to use a server side method that executes within a workflow. The method works fine if I hard-code the ID number EX - hd.setID("7811030AE0A747C7A7C1934A8C97532E")). How do I get the ID of the ITEM that is used in a form to pass to the method.
FORM is called: Min_Fielded_PR that comes from the ItemType called: Min_Fielded_PR
WORKFLOW is called: WF99
METHOD within the Workflow is called: MM99
// Method - MM99//
Item hd= inn.newItem("Min_Fielded_PR","get");
hd.setID(this.getID());
hd.setAttribute("select","item_number,description,resolution");
hd=hd.apply();
return this;
Yoann Maingon - Thursday, November 3, 2016 4:57 PM:
Hi Dominic,
Here is a community method to retrieve the controlled item when a method is triggered from a workflow event:
gist.github.com/.../817184c84b7dec9e0dd3105c9d456632
call it from your method :
Item ControlledItem = this.apply("GetControlledItem");
PS: if you owe Eli a drink, remember that you owe me a cheese steak !
didonato - Friday, November 4, 2016 12:40 PM:
Sorry Yoann, but I need baby steps to do this. -
So I created a new Method called " GetControlledItem" and pasted everthing from the site you gave me.
I modifed my Method to this:
hd.setID(ControlledItem);
hd=hd.apply();
return this;
I get error "CS1002, ; expected"
I guess I'm not calling the "GetControlledItem" Method correctly within my Method.
By the way, I think I owe you more than one cheesesteak!!
Yoann Maingon - Sunday, November 6, 2016 2:41 PM:
my first answer is that you are missing a ;
at the end of this line : Innovator inn=this.getInnovator()
try again then.
Yoann Maingon - Sunday, November 6, 2016 2:42 PM:
then in setID() you don't want to pass the item but just the Item ID
so it would be something like hd.setID(ControlledItem.getID());
didonato - Monday, November 7, 2016 6:33 PM:
THANK YOU Yoann,
That worked great. The last part to this method is retrieving the related Contact. I'm having trouble geting the ID for it. I think the problem is on the line that I underlined. What are you thoughts? It this incorrect?
Item hdRelatedContact = inn.newItem("Min_Fielded_PR_Contacts","get");
Item hdContact = inn.newItem("Min_Contact","get");
hd.setAttribute("select","item_number,description,problem_resolution");
hd.addRelationship(hdRelatedContact);
hdRelatedContact.setRelatedItem(hdContact);
hd=hd.apply();
hdRelatedContact = hd.getRelationships("Min_Fielded_PR_Contacts");
Item toUser= inn.newItem("Min_Contact","get");
toUser.setAttribute("select","email_primary");
toUser.setID(hdRelContact.getID());
toUser=toUser.apply();
Yoann Maingon - Monday, November 7, 2016 6:39 PM:
not sure as It's actually 1:00 am but try
toUser.setID(hdRelContact.getProperty("related_id"))
didonato - Thursday, November 10, 2016 1:13 PM:
I tried fixing this for hours and can't get this to work, any suggestions? I keep
getting "Not a single item" error
I tried the following and others without luck:
toUser.setID(hdRelContact.getProperty("related_id"));
Item hd= inn.newItem("MIN_Fielded_PR","get");
Item hdRelatedContact = inn.newItem("MIN_Fielded_PR_Contacts","get");
Item hdContact = inn.newItem("MIN_Contact","get");
hd=hd.apply();
hdRelatedContact = hd.getRelationships("MIN_Fielded_PR_Contacts");
Item toUser= inn.newItem("MIN_Contact","get");
