bry422 - Tuesday, September 20, 2016 3:37 PM:
Hello -
Can someone give me a walk through of what I need to do to create a Project in Aras via C# using the Aras API?
As of now, I get an error telling me the "WBS_ID" is null when I try to create a project. I think there is a Project - Project Tree relationship and I'm not sure how to set the "WBS_ID" on Project create (or anything else I need to do).
I can share code if necessary, but any help would be appreciated.
Bryan
bry422 - Wednesday, September 21, 2016 11:23 AM:
This does NOT work. Not ever sure how close I am.
Create the WBS...
Item mWBS = inn.newItem("WBS Element", "add");
mWBS.setProperty("name", "Test Project");
mWBS.setProperty("is_top", "1");
Item wbs = mWBS.apply();
Use the WBS ID when creating the Project...
Item mProject = inn.newItem("Project", "add");
mProject.setProperty("wbs_id", wbs.getID());
Item result = mProject.apply();
edonahue - Wednesday, September 21, 2016 2:06 PM:
Hi Bryan,
I don't have any sample code for creating a Project via a server-side method, but I believe Aras Support may be able to provide more information. I recommend contacting the Support team for assistance with your use case.
