DEVELOPERS FORUM - How to Save, Lock and Close a form in code?
handpuppet - Wednesday, August 17, 2016 3:03 PM:
To save, lock and close an item in code, I use the following command:
 parent.onSaveUnlockAndExitCommand();
This works in Firefox 32 and IE 9.  However in IE 10 this command does not work.  My question is, is there any other way in code to save, lock and close a form or is this the only command that will do that?
edonahue - Tuesday, September 27, 2016 11:41 AM:
Hi handpuppet,
Can you confirm which version of Aras Innovator you are using?
