DEVELOPERS FORUM - Query on Workflow
sahana ks - Tuesday, August 23, 2016 5:12 AM:
I am trying to promote the state of the business object through workflow.
I have a business object. I have defined a workflow and lifecycle specifically for this business object.
 I configured the workflow activities (under Promotion Tab”) to assign certain Lifecycle state as the business object moves through each activity in workflow. I also did the configuration to automatically submit business object into this workflow.
 Now when I try to create the business object and press OK I get “ItemIsLockedException”.
If I remove the lifecycle Map from the BO  ItemType the BO gets created and submitted correctly to workflow. What is the issue?
 If I use OOTB PR lifecycle map (just of testing) on this BO and with same workflow it works. I compared my Lifecycle map with PR cycle Map and don’t see much difference.
Appreciate help here.
edonahue - Monday, September 19, 2016 11:53 AM:
Hi Sahana,
Can you provide some screenshots of your Workflow and Life Cycle so I can review the configuration? Thanks.
