DEVELOPERS FORUM - Django Application integrating with ARAS Innovator
gchansc - Tuesday, August 9, 2016 10:57 AM:
I got a Django Application (Python Framework) running, and I am looking into integrating with ARAS Innovator 11.
Does anyone had success or know what protocol is best-suit for this situation of integration?
Any expert suggestion or recommendation will be very useful.
Thank you very much!
edonahue - Thursday, August 11, 2016 10:04 AM:
Hi gchansc,
Can you provide a little more information on this integration? What type of functionality are you trying to implement?
gchansc - Sunday, August 21, 2016 11:52 AM:
Hi Eli,
Thank you for your reply and questions.
I am looking to see if I can getting data from Aras Innovator, such as BOM/MPP data, using some kind of connection like,  SOA/Restful Service? Is Aras suitable or support this integration?
Thank you for your expertise!
edonahue - Monday, September 19, 2016 3:19 PM:
Hi gchansc,
Third party integrations typically use Aras' IOM (Innovator Object Model) to request data from the server using JavaScript or C#. I don't have any specific samples for integrating Aras with Django at this time.
I recommend contacting the Aras Community team - they should be able to provide more information or put you in touch with someone on the Aras Professional Services team.
kzgs - Thursday, October 27, 2016 11:46 AM:
It is not recommended in the Programers Guide, but SOAP API seems to be available.
Yoann Maingon - Thursday, October 27, 2016 12:45 PM:
"not recommended" I don't think Aras discourages it.
It's the way to go if you are not running on a .net framework.
You can use a SOAP client library for Python : pypi.python.org/.../SOAPpy
Look at this thread : www.aras.comhttp:/.../648.aspx
Pascal Morenton from France made a simple but efficient integration between Catia and Aras Innovator using Visual Basic but without using the IOM. Pure SOAP request !
