DEVELOPERS FORUM - On Click button on form and refresh grid with current data
Shankar - Saturday, June 25, 2016 6:48 AM:
hello developers,
I have created grid + button on html field and on click event i want to add data from current tab and reload my grid from client side code
function dostandarddetail()
 var itemtypeID = top.aras.getItemTypeId("Symbi_PackMaterialRcons_Detail");
 var param = { aras: top.aras, itemtypeID: itemtypeID, multiselect: true };
 var options = { dialogWidth: 700, dialogHeight: 450 };
 //getHeaderForPackRecon();
 var results= top.aras.modalDialogHelper.show('DefaultModal', window, param,  options, 'searchDialog.html');
for (var i = 0; i < results.length; i++)
var result = results[i];
var item = document.thisItem;
var vpack = item.newItem("Symbi_Pack_MterialRecons","add");
var fmi=item.newItem("Symbi_PackMaterialRcons_Detail","get");
fmi.setProperty("id",result);
var resfm=fmi.apply();
var vATRPara = item.newItem("Symbi_PackRecons_Detail","add");
vATRPara.setProperty("source_id",item.getID());
vATRPara.setProperty("related_id",result);
vATRPara.setRelatedItem(fmi);
vpack.addRelationship(vATRPara);
var res=vATRPara.apply();
var lstatus=document.thisItem.getLockStatus();
if(lstatus==1||lstatus==2 )
var it= top.aras.saveItemEx(document.thisItem.node,false);
top.aras.uiReShowItemEx(document.itemID,it);
top.aras.work.searchContainer.runSearch();
 alert("test");
edonahue - Thursday, July 7, 2016 6:44 PM:
Hi Shankar,
You can define the onClick event for your button in the HTML field using standard Javascript. In your custom onClick handler, reinitialize your grid control to refresh the display.
Note: Innovator's OnClick Field Events do not work with buttons embedded in an HTML field.
