APPLICATION - PRODUCT ENGINEERING - Hyperlinks in email notifications not working in 11 Sp5 build 6296
Bryanjscott777 - Tuesday, June 14, 2016 3:19 PM:
Normal 0 false false false false EN-US X-NONE X-NONE
Good afternoon,
I am having trouble with hyperlinks in email notifications after setting up a new test instance of 11SP5 build 6296.
On the original test instance (11  build 6073), the following string would launch Aras and open the item associated with the GUID:
umcapptest01/.../default.aspx
In the new 11sp5 instance build 6296, I replaced the umcapptest01/innovator with new values, but I now see the following errors:
The method “selectStartPage” failed.
Technical Message    aras_object: “undefined” : “aras.setup_query.StartItem.split is not a function”
Stack Trace     Client Side Error
and
The method “runStartPage” failed.
Comparing the (2) methods (“selectStartPage” and “runStartPage”) from the 2 instances, it appears that a change was made to these 2 files as follows (not sure if/how this affects the hyperlinks):
11 build 6073:  top.aras.setup_query.StartItem
11 sp5 build 6296:   aras.setup_query.StartItem
 “selectStartPage”:
11 build 6073:
if (!top.aras || !top.aras.setup_query || !top.aras.setup_query.StartItem) return;
if (top.aras.setup_query.StartItem == 'inbasket')
  return 'InBasket Task';
var arr = top.aras.setup_query.StartItem.split(":");
var type = arr[0];
var id = arr[1];
if (type && !id) return type;
11 sp5 build 6296:
if (!aras || !aras.setup_query || !aras.setup_query.StartItem) return;
if (aras.setup_query.StartItem == 'inbasket')
var arr = aras.setup_query.StartItem.split(":");
var type = arr[0];
var id = arr[1];
“runStartPage”
11 build 6073:
if (!top.aras.setup_query.StartItem) return;
var type = arr[0];
var id = arr[1];
if (!type || !id) return;
var itm = top.aras.getItemById(type, id, 0);
if (itm)  top.aras.uiShowItemEx(itm, undefined);
11 sp5 build 6296:
if (!aras.setup_query.StartItem) return;
var type = arr[0];
var id = arr[1];
var itm = aras.getItemById(type, id, 0);
if (itm)  aras.uiShowItemEx(itm, undefined);
Am I missing something stupid here?
Can anyone help with a fix of provide guidance?
edonahue - Wednesday, June 15, 2016 11:05 AM:
Hi Bryan,
This is a known issue in Innovator 11.0 SP5 that will be resolved in a future version of Aras Innovator.
However, the following workaround may resolve this issue for you:
  1. Navigate to your code tree in a file browser (the root installation directory, default C:Program Files (x86)ArasInnovator)
  2. Open InnovatorClientscriptsmainTree.html for editing.
  3. Insert the highlighted lines code and save the file.
topWindow.arasMainWindowInfo.arasMainWindowLoading = false;
var startItem = topWindow.aras.setup_query["StartItem"];
if (startItem) {
// Workaround for StartItem
startItem = typeof(startItem)=="object" ? startItem[0] : startItem;
var itemInfo = startItem.split(":");
topWindow.aras.uiShowItem(itemInfo[0], itemInfo[1], "tab view");
Please be sure to clear your browser cache after making these changes.
Bryanjscott777 - Wednesday, June 15, 2016 11:38 AM:
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
Good morning Eli,
Thank you so much for the quick response!
I was able to make the modification to the mainTree.html file that you recommended and the object will now load from the email notification hyperlink, however, I still get the error messages from the “selectStartPage” and “runStartPage” methods about .split not being a function, should these error messages still be popping up?
Thanks,  Bryan
edonahue - Monday, June 20, 2016 10:24 AM:
Hi Bryan,
You should be able to prevent those errors if you explicitly convert StartItem to a string before the .split() function. You will need to do so in both the selectStartPage and runStartPage Method items in the database.
Replace:  aras.setup_query.StartItem.split(":")
With:  aras.setup_query.StartItem.toString().split(":")
Bryanjscott777 - Monday, June 20, 2016 10:35 AM:
Good morning Eli,
Works perfect!!!
Thank you so much :)
Bryan
