DEVELOPERS FORUM - InBasket Task not support multilingual
mark_chen - Friday, June 17, 2016 5:21 AM:
Hi friends,
I am using Aras 11SP5
I try the InBasket Task (configurable Inbasket), I found My InBasket doesn't support the multilingual , what I am missing??
Thanks in advance
edonahue - Monday, June 20, 2016 11:57 AM:
Hi mark_chen,
The configurable InBasket does support multilingual strings, it just requires a little more configuration than standard grids. The configurable InBasket uses a SQL view to pull the grid content. You will need to update the workflow_task SQL view in the database to use the preferred language from the multilingual string instead of the default.
mark_chen - Tuesday, June 21, 2016 3:33 AM:
Hi Eli Donahue
 It works well
 Thanks very much
