SUPPORT Q&A - SQL error with each opening of a section of "Contents"
brendan.leguisquet - Wednesday, May 25, 2016 9:46 AM:
Normal 0 21 false false false FR X-NONE X-NONE
Hello everyone,
After launching Aras Innovator 11.0 SP5 Build: 6296, most sections of the "Contents" menu displays the error below.
In English, that given below (for the start) :
"The name of the column 'LABEL' is specified multiple times in the SET clause. It isn't possible to assign multiple values to a column in the same SET clause. Modify the SET clause so that a column is updated only once. If the SET clause updates columns of a view, the name of the column 'LABEL' may appear twice in the view definition. in SQL: INSERT INTO..."
In your opinion, where do I change set SET clause for resolve this error?
Thanks for your help and suggestions
Regards
