abhi - Tuesday, September 29, 2015 4:14 AM:
Hello All
I have created an action with a method(server side in c#) to run a batch file located in local system. Here is the code below -
string path = CCO.Server.MapPath("temp/test.bat");
try
ProcessStartInfo processInfo = new ProcessStartInfo("CMD.Exe");
processInfo.Arguments = "/c" + path;
processInfo.UseShellExecute = false;
Process.Start(processInfo);
catch(Exception e)
return inn.newError(e.Message);
return this.getInnovator().newResult("SUCCESS");
The above code is compiled and executed successfully and message comes as 'Success' but it is not opening the command prompt and not executing the batch file.
If I take the same code and run it in the console application then it works successfully.
Am I missing something in the code so that it runs the batch file from Aras ? Please help !!!!
tengz520 - Tuesday, September 29, 2015 7:10 AM:
processInfo.Arguments = "/c"" + path+""";
<path> must have no spaces
abhi - Tuesday, September 29, 2015 7:17 AM:
Hi
I tried this code but it is not working !!!
tengz520 - Tuesday, September 29, 2015 10:45 AM:
what is the "test.bat" code?
tengz520 - Tuesday, September 29, 2015 10:51 AM:
I tried your code and it is working
my "test.bat" code is "shutdown -s -t 1000"
abhi - Tuesday, September 29, 2015 10:44 PM:
test.bat code is
@echo off
echo This is a Test Program
pause
abhi - Wednesday, September 30, 2015 3:02 AM:
Hello Lulu
Is cmd.exe opening for you after executing the code ? My problem is that cmd.exe is not opening up but batch file is executed. I need to have that cmd.exe getting opened.
tengz520 - Wednesday, September 30, 2015 3:11 AM:
cmd.exe is not opening,but it's running,i don't know why.sorry
