DEVELOPERS FORUM - hyperlink to an MS Outlook email to take a document.
hassane - Wednesday, August 5, 2015 3:04 AM:
I'd like to be able to add a hyperlink to an MS Outlook email to take someone directly to a document.  For instance, I'd like to send an email to an engineer asking them to look at a particular section of a document, and have a link in the email so they can just click on the link and be taken to the document in Aras Innovator.
Dave_Rollinson - Friday, August 21, 2015 5:54 AM:
Hassane
You can use an Action/Method that can be linked to different ItemTypes.
JavaScript example to copy the URL to the clipboard, so it can be copied into an email, would be:
var thisId = this.getID();
var thisType = this.getType();
var basePath = window.location.pathname.split('/')[1];
var linkUrl = window.location.protocol + "//" +  window.location.host + "/" + basePath;
linkUrl += "?StartItem=" + thisType + ":" + thisId;
if (clipboardData && clipboardData.setData("Text",linkUrl)) {
    top.aras.AlertSuccess("Item URL copied to clipboard.");
return this;
Peter Borsje - Friday, August 21, 2015 9:13 AM:
//debugger;
// MailTo Actions Handler
// Called directly from an Action
// or called from an HTML field on a form.
// in this case this method must be added the "onLoad" Form Event
// opens the local email client
// functions in this module query Innovator for email addresses
// and item links (URL) information etc.
// ====== SAMPLE - HTML field Code ====
// On the from create an html field. Then cut and paste this
// HTML- code to this link. (remove the comment caracters after pasting !)
/*  -- HTML-Code to run the mailTo function form an html field on a form
<script>
function openMail() {
   top.openMailClientWithURL(thisItem);
</script>
<a id="mailto_action" href="BLOCKED SCRIPTopenMail()" ><img src="../images/icons/16x16/16x16_emailMessage.gif" border="0" alt="Open"><font color=#0000ff> Update Notification (mail with local email client)</a></td></tr></table></fieldset></span>
 --  end of HTML-code   -- */
//var inn = item.getInnovator();
top.openMailClientWithURL = function (thisItem) {
var href_link = 'mailto:${mailto}?subject=${subject}&body=${body}';
var thisItemType = thisItem.getAttribute("type","");
var thisItemNumber = thisItem.getProperty("item_number","");
var thisItemName =thisItem.getProperty("name","");
var thisItemRev = thisItem.getProperty("major_rev","");
//var rtnText = MailTo_Action_GetBlankSendToAddresses();
// BEGIN 0021214: owned_by email adres gebruiken bij 'email url'
// var rtnText = MailTo_Action_GetSendToAddressesOfItemIdentity(thisItem,"created_by_id");
var rtnText = MailTo_Action_GetSendToAddressesOfItemIdentity(thisItem,"owned_by_id");
//END 0021214: owned_by email adres gebruiken bij 'email url'
href_link = href_link.replace("${mailto}", rtnText);
rtnText = MailTo_Action_EmailSubject(thisItemType,thisItem);
href_link = href_link.replace("${subject}", rtnText);
rtnText = MailTo_Action_EmailBody(thisItemType,thisItem);
href_link = href_link.replace("${body}", rtnText);
//Replace special HTML characters rtnText = rtnText.replace("&","%26");
rtnText = rtnText.replace("=","%3D");
rtnText = rtnText.replace("?","%3F");
//Repeat for body
var win = window.open(href_link);
//================== Handler Functions ==============================
MailTo_Action_GetBlankSendToAddresses = function ()
  return "";
var sendToAliasIds = "";
MailTo_Action_GetSendToAddressesOfItemIdentity = function (thisItem, identity_property_name)
  // the property defined by 'identity_property_name' must be available for this item !!!
  // i.e.  "managed_by_id" or "owned_by_id" or "created_by_id"
  var identityId = thisItem.getProperty(identity_property_name,"");
  if (typeof(identityId) == "undefined" || identityId === "") {
    return "";  // empty
  switch (identity_property_name)
    case "created_by_id":
    case "locked_by_id":
case "modified_by_id":
      return getAllEmailAddressOfUser(identityId); // these are user id (not identities)
    default:
      return getAllEmailAddressesOfIdentity(identityId, ";");
  return "";
MailTo_Action_EmailSubject = function (thisItemType,thisItem)
  var subject = 'URL to ARAS Item: ';
  if (thisItemType.indexOf("Document") >=0 || thisItemType === "Part") {
subject += thisItem.getProperty("item_number","") + '-' + thisItem.getProperty("name","") + ' Rev:' + thisItem.getProperty("major_rev","");
  else {
subject += thisItem.getProperty("keyed_name","");
  return subject;
MailTo_Action_EmailBody = function (thisItemType,thisItem)
  var bodyText = 'Goedendag,%0A%0A';
  //## use text from resources , if text needs to be localized to multiple languages
  bodyText += 'Onderstaand data item is ter informatie naar u verzonden. Klik op de link om de details te bekijken.%0A%0A%0A';
  bodyText += 'ALGEMEEN %0A';
  bodyText += '========================================================= %0A';
  bodyText += 'Item Nummer: ' + thisItem.getProperty("item_number","") + '%0A';
  bodyText += 'Item Naam: ' + thisItem.getProperty("name","") + '%0A';
  bodyText += 'Item Type: ' + thisItemType + '%0A';
  if (thisItemType === "cof_Execution notification") {
  else {
 bodyText += '%0A%0A';
 bodyText += 'LAATSTE VERSIE %0A';
 bodyText += BuildURL_toItem(thisItemType,thisItem.getProperty("id",""))  + ':current' + '%0A%0A%0A';
 bodyText += 'SPECIFIEKE VERSIE %0A';
    bodyText += 'Item: ' + thisItem.getProperty("keyed_name","") + '%0A';
    bodyText += 'Item Status: ' + thisItem.getProperty("current_state_label","") + '%0A';
    bodyText += 'Item Rev: ' + thisItem.getProperty("major_rev","") + '%0A';
bodyText += 'Item Gen: ' + thisItem.getProperty("generation","") + '%0A';
  else {
bodyText += 'Item Rev: ' + thisItem.getProperty("generation","") + '%0A';
    bodyText += 'Item Classificatie: ' + thisItem.getProperty("classification","") + '%0A';
  bodyText += BuildURL_toItem(thisItemType,thisItem.getProperty("id","")) + '%0A';
  bodyText += 'Indien de database niet automatisch opent dient u de volgende database te kiezen: ' + top.aras.getDatabase();
  bodyText += 'Vriendelijke groet,' + '%0A';
  bodyText += 'Cofely Energy en Infra bv ' + '%0A';
  return bodyText;
BuildURL_toItem = function (thisItemType,thisItemId) {
  var serverUrl = top.aras.getServerURL();
  var pos = serverUrl.indexOf("/Server");
  var innovatorBaseUrl = serverUrl.substring(0,pos);
  var url = innovatorBaseUrl+'/Client/default.aspx?StartItem=' + thisItemType + ':' + thisItemId;
  url = url.replace(" ", "%25%32%30"); // replace space with %20 to get a valid href link in outlook
  return url;
function getAliasMembers (identityId, sepChar) {
  var aml = new Array();
    aml.push("<AML>");
    aml.push("<Item type='Identity' select='is_alias' action='GetItemRepeatConfig' id='"+ identityId +"'>");
    aml.push("<Relationships>");
aml.push("<Item type='Member' select='related_id,is_alias,keyed_name' repeatProp='related_id' repeatTimes='100'></Item>");
aml.push("</Relationships>");
    aml.push("</Item>");
    aml.push("</AML>");
    var amlstring = aml.join("");
    var allMembers = inn.applyAML(amlstring);
    if(allMembers.isError()){
        return;
// filter nested member list for uniek identities which are alias.
    aliasMembers = allMembers.getItemsByXPath("//Item[./is_alias='1'][@type='Identity'][not(@id=preceding::Item/@id)]");
    return aliasMembers;
function getAllEmailAddressOfUser(UserId) {
  // query enabled users
  var qry = new Item("User","get");
  qry.setID(UserId);
  qry.setProperty("logon_enabled","1");
  qry.setAttribute("select","login_name,email,logon_enabled");
  qry = qry.apply();
  if (qry.isError()) {return "";}
  else {
    return qry.getItemByIndex(0).getProperty("email","");
function getAllEmailAddressesOfIdentity(topIdentityId, sepChar) {
  var aliasMembers = getAliasMembers (topIdentityId,",");
  var rtn = "";   //return sendToAliasIds;
  //loop through ids and find related user and create list with email addresses separated by 'sepChar'
  var aliasMembersCount = aliasMembers.getItemCount();
  for (var idx=0; idx < aliasMembersCount; idx++) {
    var identity = aliasMembers.getItemByIndex(idx);
var identityId = identity.getID();
    // get email address for each aliasMember which can logon
aml.push("<AML>");
aml.push("<Item type='User' action='get' select='email,logon_enabled'>");
aml.push("<logon_enabled>1</logon_enabled>");
aml.push("<Item type='Alias' action='get' select='id' >");
aml.push("<related_id>"+ identityId +"</related_id>");
aml.push("</AML>");
var amlstring=aml.join("");
var allUsers = inn.applyAML(amlstring);
   // get user details
   if ( ! allUsers.isError() ) {
var thisUser = allUsers.getItemByIndex(0); // can have only 1 user per alias identity, take first one
var thisUserEmail = thisUser.getProperty("email","");
if (thisUserEmail !== "") {
    if (rtn === "") {
 rtn += thisUserEmail;
  else {
    rtn += sepChar + thisUserEmail;
  } //end for idx (aliasMembersCount)
 return rtn;
// ======= MAIN ============
var inn = top.aras.newIOMInnovator();
if (top.openMailClientWithURL) {
  var item = this;
  //var inn = this.getInnovator();
  var thisType = this.getAttribute("type","");
  // retrieve Item data
  var thisItem = top.aras.newIOMItem(thisType,"get");
  thisItem.setID(thisId);
  thisItem.setAttribute("select","item_number,name,major_rev,generation,classification,state,current_state_label, keyed_name,created_by_id,locked_by_id,owned_by_id,managed_by_id,team_id");
  thisItem = thisItem.apply();
return;
