lena - Saturday, September 13, 2014 5:25 AM:
I want to Consume a Web Service in a Server Method .
I have created a Proxy DLL that represents the connection to the remote server
, installed the Proxy into the Innovator Server code tree
,and declared the Proxy’s name space within Innovator Method
or so created an instance of the Proxy inside a specific server method, and transfer data.
But When I applying the method ,it provoids wrongs:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="http://www.aras.com/InnovatorFault"><faultcode>SOAP-ENV:Server</faultcode>
<detail><af:legacy_detail>
The server was unable to process the request.Object reference not set to an object instance
</af:legacy_detail>
<af:exception message="
The server was unable to process the request.Object reference not set to an object instance" type="System.Web.Services.Protocols.SoapException" />
</detail></SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
My code is as follow:
EDIService ed = new EDIService(); ---> my web service
DataSet ds = ed.GetDataInfo("iTEC_MES"," MaterialStock", "11", "MCH000001MSAA", "F11", "", "", "", "IfxByFormNo");
// when debuge here it coms out wrong!
int count= ds.Tables[0].Rows.Count ;
Strangly, when I apply method in Visual Studio. It works well.
Please help me ! Thanks regard!
tstickel - Wednesday, September 17, 2014 1:56 PM:
As a first guess, you did not mention that you had updated the Innovator method-config.xml file (found in .../innovator/server folder) to include the reference to system.web.services.dll and a reference to the EDI proxy .dll. Can you verify that this has been done.
