jiteshpanchal - Tuesday, May 27, 2008 10:51 AM:
Hello, I have just installed Aras Innovator 3.0.0 Build 5423.
When I try to login to Aras Innovator, I receive the following message:
Exception during initialization (InnovatorDatabaseException: Invalid object name 'ITEMTYPE'. in SQL: SELECT id FROM ITEMTYPE WHERE name = 'Locale')
I would be extremely grateful if anyone can help me with this problem.
Bill - Monday, June 2, 2008 11:16 PM:
I haven't seen this error before, but I will recommend that you go to http://www.aras.com/support/downloads/download.aspx and download a new copy of the installer.
If installing a new version doesn't fix the problem, please let me know what version of SQL server you are using, what OS you are using for client and server, and what language/region your clint OS is set for.
-Bill
mgalvan801 - Tuesday, May 22, 2012 4:19 PM:
This is for SQL Server issues only:
The issue is where the Login Properties for innovator under server roles were set to:
public
serveradmin
sysadmin
The login server role should be set to public only.
Once I unchecked the other roles and had it set to public only, it didn't have this issue anymore.
MGalvan801
piko - Tuesday, September 16, 2008 7:15 AM:
Did you find the solution to your problem? I'm facing the same one and got stucked with starting Aras.
piko
V Manivannan - Thursday, July 16, 2015 6:27 AM:
Hi Marty Galvan,
I selected the login server role only for public and It works fine for me.
V.Manivannan
Bill - Friday, October 3, 2008 3:46 PM:
I recieved no followup. If you wish to tell me the details of your setup, I can extend the same offer to you.
-Bill
sherenegladysj - Friday, June 5, 2009 10:00 AM:
Hi Bill and all,
Just noticed your discussion on this topic... the following is my system configuration
Sql Server: Express Edition 2005
WinXp with SP2
I am getting the following error while trying to login to Aras Innovator login page
" Invalid object name 'LOCALE' "
I am receiving this message no matter the user name & password is correct or wrong.
Have you come across such a scenario? Please help. Thanks in avance.
mmuthuka - Tuesday, September 15, 2009 3:50 PM:
I also got the same error message
Invalid Object Name LOCALE when i tried to login first time after installation.
Did you find any solution for the above problem?
Selvi
Bill - Tuesday, September 15, 2009 5:30 PM:
I have never solved this issue through the forum. However every time I have encountered this issue outside of the forum, the problem was that the database was installed with a DBA login like the default sa login. This causes the database objects to have the wrong owner, and the SQL queires subsequently fail.
I recommend reinstalling, it will be fastest. just make sure to use a completely new login in the "Database Login Options". You will need to manually delete the existing database before reinstalling.
sherenegladysj - Wednesday, September 16, 2009 1:46 AM:
Hello Selvi,
You are getting the error message because the username and Password is not set for the SQL Server. Database is not configured perfectly.
I resolved this issue by reinstallation of Aras. Please follow the Instructions carefully given in the pdf file while installing the Aras.
All the best...
Sherene
francisco - Friday, September 24, 2010 10:10 AM:
HI,
I have received the same error when liging in for the first time. I have read your comments and I have a question:
Do you have to uninstall "Aras Innovator" from the control panel Add or Remove Programs?
Do you have to delete the database from SQL?
Please advice!
Thank you
francisco - Wednesday, October 6, 2010 5:21 PM:
If you were able to solve the problem by re installing the software, did you do any modification in SQL?
if so, what was it?
I just re installed the Aras software and got the same problem. I don't see instructions on how to install the SQL
software.
Please advice.
Thank you
