gunner_hk - Monday, November 19, 2012 3:47 AM:
I did set up ARAS over a year ago. Our company is now revisiting it and I am having slight difficulties in setting it up again.
I installed the latest version 9.3.0 onto Windows Server 2008 R2 with IIS installed. I keep getting the error message:
THE CONFIGURATION SECTION CANNOT BE USED AS THIS PATH. THIS HAPPENS WHEN THE SECTION IS LOCKED AT A PARENT LEVEL........
(OVERRIDEMODE="DENY", OR SET EXPLICITLY BY A LOCATION TAG WITH OVERRIDEMODE="DENY" OR LEGACY ALLOWOVERRIDE="FALSE".
CONFIG FILE ARASINNOVATORINNOVATORWEB.CONFIG
<system.webserver>
<handlers accesspolicy="read, script" />
<directorybrowse enabled="false">
This is the web.config actual file:
?xml version="1.0" encoding="UTF-8"?>
<configuration>
<system.webServer>
<handlers accessPolicy="Read, Script" />
<directoryBrowse enabled="false" />
<defaultDocument>
<files>
<clear />
<add value="Default.aspx" />
<add value="default.asp" />
<add value="index.html" />
<add value="index.htm" />
<add value="default.html" />
<add value="default.htm" />
</files>
</defaultDocument>
<httpErrors>
<clear />
</httpErrors>
</system.webServer>
</configuration>
Much appreciated for any help.
Matthew
vasant - Tuesday, November 20, 2012 12:24 AM:
Hi Matthew,
you can write web.config as:
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
<system.webServer>
<defaultDocument>
<files>
<clear />
<add value="default.aspx" />
</files>
</defaultDocument>
</system.webServer>
</configuration>
And also enable the defaultDocument Setting from IIS Server
refer following URL for above:
www.iis.net/.../defaultdocument
Hope it helps..
Thanks & Regards,
Vasant
gunner_hk - Tuesday, November 20, 2012 3:16 AM:
Vasant,
Thanks for replying back to me. I tried to above but no such luck. I wished I had remembered where those notes were now from a year ago. I do recall when I first installed ARAS I encountered the same problem. I did get it working in the end but just can't remember what I did?
Do you have any more ideas?
Matthew
