"The operation was canceled." message while logging in.
Hello All,
Installed Aras on Windows10 machine.
Using .Net Framework 4.7.2 as specified in the installation document.
When I try to login to Aras (using admin/innovator),
it takes sometime and finally shows the below message in the login screen:
Tried with Edge & Chrome too.
Any input on how to fix this?
Thank you very much for your help.
Jai
  • Hi Jaiganesh
    Ensure that SQL Server is running in services.
    Step 1: Press Windows Key + R (to open run)
    Step 2: Type services.msc
    Step 3: Search for SQL Server
    Step 4: Right click and select Start (If not running)
    Thank You
    Gopikrishnan R
  • オフライン in reply to Gopikrishnan
    Hi Gopi,
    Thanks for your reply.
    Yes, SQL Server is running & I'm not able to login still.
    Any input would be appreciated.
    Jai
  • Hi,
    Resolved it & now I’m able to login.
    The issue was the server entry in DB-Connection in config file.
    Previously it was…
    <DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="localhost"
    Now changed it to…
    <DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="MyMachineName\SQLEXPRESS"
    Thanks for your time in this.
    Jai
