I installed Aras on windows server 2012 R2. Also downloaded >NET 4.7.2 as specified on the install but getting a message saying it is already installed.
When I try to login to Aras, I am getting the error below. Any input on how to fix this?
Thank you very much for the help.
Pf
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: The 'targetFramework' attribute in the <compilation> element of the Web.config file is used only to target version 4.0 and later of the .NET Framework (for example, '<compilation targetFramework="4.0">'). The 'targetFramework' attribute currently references a version that is later than the installed version of the .NET Framework. Specify a valid target version of the .NET Framework, or install the required version of the .NET Framework.
Source Error:
Line 82: </clientTarget>
Line 83:
Line 84: <compilation>
Line 85: <assemblies>
Line 86: <add assembly="mscorlib" />
Source File: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Config\web.config Line: 84
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.8.4075.0
