while installing ARAS 12 I am getting below warning:
CANNOT CREATE CORRECT OAUTH SERVER.
After that Installation completed.But while login to ARAS 12 Below error will come
Do anyone know what to do?
Hi Tejaswini,
Did you get an error during installation stating that the OAuth server config or web file was not created? If that was the case I would check the following:
1. Make sure you have the correct .net core and asp.net core installed
2. Check your environment variables to ensure that path points to the installed .net
Best,
Nithin
