We installed Innovator 11SP12 and then installed the CAD to PDF converter. It converts Solidworks to PDF in CAD documents no problem.
Then we installed MPP11.0R3 and created a simple process plan.
When we try to publish the process plan to HTML or PDF the conversion task fails. The error is:
Aras.ConversionFramework.Exceptions.EventCallbackErrorException: See inner exception for details: ---> System.Exception ---> System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.IO.FileLoadException: Could not load file or assembly 'Conversion.Base, Version=11.0.0.6812, Culture=neutral, PublicKeyToken=524d880b05474146' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
at System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMarkHandle stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName, ObjectHandleOnStack type)
at System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName)
at System.Type.GetType(String typeName)
at Aras.ConversionFramework.ConverterCreator.GetType(String converterName) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionService\ConverterCreator.cs:line 43
at Aras.ConversionFramework.ConversionServer.ConversionService.Convert(String taskAML) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionService\ConversionService.cs:line 104
--- End of inner exception stack trace ---
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult)
at Aras.ConversionFramework.Proxy.ConversionService.EndConvert(IAsyncResult asyncResult) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\_CommonFiles\ConversionService\ConversionService.cs:line 84
at Aras.Server.Core.InvokeStandardConverter.ConvertCallback(IAsyncResult ar) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\InternalMethods\InvokeStandardConverter.cs:line 110
at Aras.ConversionFramework.Models.ConversionTask.<>c__DisplayClass40_0.<OnConvertCompleted>b__1() in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 280
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 182
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 257
at Aras.ConversionFramework.Models.ConversionTask.ExecuteEventHandlers(ConversionTaskEventType eventType) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 346
I highlighted the part that seems to be the issue - the CAD to PDF installation updates the Conversion.Base.dll and ConversionManager.dll to version 11.0.0.6920 (from 11.0.0.6812).
Both files are in three locations on the server -
Innovator\Server\bin
Innovator\ConversionServer\bin
Innovator\AgentService\bin
Oddly, the Supprt Matrix at https://www.aras.com/SubscriberPortal/support.aspx shows that Innovator11.0SP12 supports MPP11.0R3 with hotfix-054618 (which says it is for Innovator11.0SP11) but the hotfix didn't help anything.
Does anyone have this working? Any ideas?
Thanks!
