I try create "innovator_regular" in User of Database for Aras SP12. But when I login, I get the following error:
Procedure or function secured.FILECONTAINERITEMS has too many arguments specified. in SQL: /*
IMPORTANT:
List of parameters to be replaced before DB Function creation:
[innovator].[GetFileContainerItem_ExcludeRepresentationFile]
/*GetFileContainerItem marker*/
CREATE FUNCTION [innovator].[GetFileContainerItem_ExcludeRepresentationFile]
@type_id char(32),
@item_id char(32),
@perm_type VARCHAR(32),
@identity_list VARCHAR(MAX),
@ip_address VARCHAR(32),
@cur_user_id CHAR(32),
@env_attrs XML)
RETURNS @IDS TABLE(ID CHAR(32) COLLATE database_default PRIMARY KEY)
AS
BEGIN
INSERT INTO @IDS
SELECT id FROM [secured].[FILECONTAINERITEMS](@perm_type, @identity_list, @ip_address, @cur_user_id, NULL, @env_attrs) container
WHERE container.[ITEMTYPE] = @type_id AND
container.[id] = @item_id AND
container.[ITEMTYPE] <> '21121ADEF2C64B2AB86C94371122DEFD' /* Exclude fr_RepresentationFile */
RETURN
END`
Can you hep me?
Thank you
Henry Tu
Hi Henry,
The innovator_regular user is a SQL user required by Aras. It should be created automatically the first time you install an 11 SP12 database to a SQL server using the installer MSI. I do not recommend creating an Aras User - that is, a User item inside the database - called innovator_regular. I don't know whether it will cause technical trouble, but it's almost sure to cause confusion for admins.
Eli
Eli Donahue
