I got the following error message from InvokeStandardConverter method for OnConvert Event of Conversion Task.
Aras.ConversionFramework.Exceptions.EventCallbackErrorException: See inner exception for details: ---> System.Exception ---> System.Net.WebException: The request failed with HTTP status 404: Not Found.
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult)
at Aras.ConversionFramework.Proxy.ConversionService.EndConvert(IAsyncResult asyncResult) in E:\Builds\Innovator_RELS11-0-SP11\6812-RELS11-0-SP11\Innovator.git\CompilableCode\_CommonFiles\ConversionService\ConversionService.cs:line 85
at Aras.Server.Core.InvokeStandardConverter.ConvertCallback(IAsyncResult ar) in E:\Builds\Innovator_RELS11-0-SP11\6812-RELS11-0-SP11\Innovator.git\CompilableCode\Core\InternalMethods\InvokeStandardConverter.cs:line 110
--- End of inner exception stack trace ---
at Aras.ConversionFramework.Models.ConversionTask.<>c__DisplayClass40_0.<OnConvertCompleted>b__1() in E:\Builds\Innovator_RELS11-0-SP11\6812-RELS11-0-SP11\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 280
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in E:\Builds\Innovator_RELS11-0-SP11\6812-RELS11-0-SP11\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 143
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in E:\Builds\Innovator_RELS11-0-SP11\6812-RELS11-0-SP11\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 185
at Aras.ConversionFramework.Models.ConversionTask.ExecuteEventHandlers(ConversionTaskEventType eventType) in E:\Builds\Innovator_RELS11-0-SP11\6812-RELS11-0-SP11\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 346
I installed Agent Service, Conversion Server and Innovator in a separate folders.
I am using Innovator11.0 SP11 version.
Which one I need to check ?
Here are current configurations.
https://drive.google.com/open?id=1-ixqePjWrGO6jHLtXt3Hmk8MVxKTu5bkhttps://drive.google.com/open?id=1HZp52qai7x1J2RiS0WRJuUks3DtByWIn
Myo Thet
I am getting this exception while converting sldprt file to PDF...
1. Conversion Server Setup for CAD files:
a. Modified ConversionServerConfig.xml file as following:
<ArasCadConverter>
<Application converterPath="C:\Program Files (x86)\Aras\Innovator\ConversionServer\HOOPS Converter\bin\converter.exe" />
<Command arguments="--input_pdf_template_file 'C:\Program Files (x86)\Aras\Innovator\ConversionServer\HOOPS Converter\templates\Blank_Template_L.pdf' --output_pdf '%filepath%\%filename%.pdf' --output_png '%filepath%\%filename%.png' --output_png_resolution '150x150' --output_prc '%filepath%\%filename%.prc' --output_logfile '%filepath%\%filename%'" />
</ArasCadConverter>
b. CAD Document created with Type as MCAD/Part and Authoring tool as “Solidworks” with file ( TEST_CAD_1.sldprt) attached as native file.
c. Saved and unlock the CAD Document.
d. Conversion process kicks up.
e. Completes the conversion process
f. Converted files gets into ARAS as after the conversion we can query and see those files.
g. Conversion process fails at “OnAfterConvert” and throws the following error:
Aras.ConversionFramework.Exceptions.ItemErrorException: Representation file id is not specified
at Aras.ConversionFramework.Models.DAL.ItemContext.AssertItem(Item item) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\DAL\ItemContext.cs:line 120
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 220
at Aras.ConversionFramework.Models.ConversionTask.ExecuteEventHandlers(ConversionTaskEventType eventType) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 346
