Self Service Reporting, Concatenate Property Values
Hi All, I am trying to build a Basic report using SSRS.
I have a requirement where in I want to concatenate values of two Properties and show it in a single Column, Is that Possible using SSRS ?
Eg. the Item Type Name and Label should be displayed as "Name(Label)" in a single Column.
Will I be able to use the Expression Property to achieve the above use case ?
Also, Is there any documentation available which provides a detailed explanation on the SSRS Reporting Configurations ?
Thankyou Slight smile
