I'm going through the Student Training Guide from ACE 2019 called "Configuring Office Connector: Mapping Properties to/from MS Office Applications"
I'm following the instructions on Page 11 to create a new document type for PR (Problem Report). On hitting Save, I get the error:
The item_number property of selected ItemType has an incorrect data type
ItemType is PR and the item_number property causing the problems is Sequence out of the box, based on the Sequence called PR. I have not changed this from default
If I change the item_number property to say, string, then the new Office Connector Document Type can be saved without problem.
Is this a bug that has come in since last year? If not, can anyone explain what is going on and why using a Sequence should be a problem?
Thank you!
Tim
