Hi
I am using Aras 11SP9, browser Chrome 57.0.2987.133
When I want changed the order of columns(relationship grid layout), I dragging the column heading.
It work on the IE 11 and Firefox, but not work in the Chrome. How to fix it?
Hi Yoann
Yes, I have the same problem. And I test 3 PC, all have the same issue.
I can dragging the column heading, but it can't save to Preferences relationship grid layout.
My Client OS is Windown 7 SP1, Server Win 2008 R2 , Database SQLServer 2008 R2
oh so that's a different problem, you can drag but it doesn't save. So the next time you load the same grid it is back to the default column organisation?
Hi mark_chen,
I ran a quick test in my local instance. If I rearrange the columns in a relationship grid, close the item and then reopen it, the columns are in the default order. However the custom column order was preserved if I rearranged the columns, logged out of Innovator and logged back in.
I hope this workaround helps.
Eli
Eli Donahue
