Could you confirm if there is a PlanCodes item that has a keyed_nam of AA in the database you're batchloading into? One way to test this is by running the AML <Item type=”PlanCodes” action=”get” select=”id” doGetItem=”0″><keyed_name>AA</keyed_name></Item> directly through AML Studio or Nash (which you can get to by adding /Client/Scripts/nash.aspx to the end of your usual Innovator URL).
Additionally, could you try to remove the doGetItem attribute from that AML? It's contradictory to include when using the get action.
