Hi community,
I'm trying to get the list of all the relationshipTypes of an ItemType thanks to the REST API.
Is this possible ?
Thanks for any help !
Arnaud
Hi community,
Is this possible ?
Arnaud
My guess would be that this is related to the permissions, but I can't say I've seen this issue before. Could you check the Permissions on the RelationshipType ItemType to see if it has been changed in your system? The Permissions in a default environment look like below where World should have Get access.
I have the same configuration as yours for the RelationshipType...
I also tried to query the RelationshipTypes of the default itemType "Part" but I also get an empty array.
Just to confirm, you can see the relationships on the ItemType when you view them directly through the client, correct?
And here is the request :
Everything looks right to me...
Hi Arnaud,
I see the confusion now. You're querying the "airbus_cabin" ItemType. What you actually want to do is query the "ItemType" ItemType. The airbus_cabin itemtype has no relationship titled relationshipType, and therefore you're getting this empty array. It's also important to note that the ID you need to pass in is the ID of the airbus_cabin itemtype.
Also appending ?$select=name to the end of that query will make it easier to parse.
AJ
Oh I see how it works now. Thank you very much.
Actually, I hoped I could retrieve directly the RelationshipType of a particular ItemType.
I have to query :
localhost/.../RelationshipType
And then get the relationshipTypes I need...
