Messed up with the Default revisions
Former Member
Former Member
Ok, so while trying to change how revisions work I made the mistake of modifying the Default revisions. Now, this would not be a huge problem if it wasn't for not being able to change it back. Whenever I try to save, I get the following error message; Internal Error: the major revision "A" specified for Revision is invalid Highly frustrating. I tried creating a new "Default" revision to replace the old one where it is used but when I try to do that; Internal Error: the major revision "A" specified for ItemType is invalid. I could resort to reinstalling Innovator but I would really prefer not having to take it that far
Parents
  • Yeah, I also did this once. I changed the Default Revision Schema from "A B C" to "V B C" just to see what happens. This was the official solution from support: A quick solution is to edit the database: - Start SQL Server Management. - Expand the database InnovatorSolution and expand Tables, locate the table innovator.REVISION. - Right click and select Edit Top 200 Rows. - Change the value in the Revision-column to "A B C D”
Reply
Children
No Data
