Changing property of a tick box
Hello, Hope someone can help me, as I am not sure what is going wrong on what is a simple thing. I have a form (PR) that has a Boolean tick box (trl_on_hold) that is set as disabled on the form (so it can be seen but not changed by the users) I am trying to create a method to tick the box when the method runs. It will run as part of a workflow task (i.e. on vote it will tick the box). I have it created as a server-side method I have tried all the below but all give me errors . I'm new to development on ARAS. Can anyone see what I have done wrong, or point me in the right direction. I know in regular c# you can change the value with onhold = !onhold. Try 1 bool holder = true; this.getProperty("trl_on_hold", ""); this.setProperty("trl_on_hold", holder); return this; Try 2 Item pr = this.newItem("PR","edit"); pr.setProperty("trl_on_hold","1"); pr = pr.apply(); return pr;   Try 3 Item pr = this.newItem("PR","edit"); pr.setPropertyAttribute("trl_on_hold","is_null","1"); pr = pr.apply(); return pr; Thanks in advance
Parents
  • Try 1 : won't work because what you actually want to do is just change the boolean value ("0" or "1") Try 2 : you need to provide the PR id to edit it. Item pr = this.newItem(“PR”,”edit”); pr.setID("0830480384038403804"); pr.setProperty(“trl_on_hold”,”1″); pr = pr.apply();   Try 3: not sure what you try to do, but doesn't seem like the way to go. regarding the return, it depends the context you are running in.
Reply
Children
No Data
