Creating java classes using AML schema
Former Member
Former Member
Hi all , I want to create an application in Java which connects to aras innovator and fetch data from it . For that I want to create  java classes for  business objects  like Item , Relationship ,etc using aras aml schema using Jaxb . But there is no fixed aml schema available for it . So how can I create classes to store fetched data and metadata of business objects in aras using Java ? Is there any other way to integrate it  ? Thanks for help !
Parents
  • Former Member
    Former Member
    The Aras AML schema is documented in the "XSLT Report Tool Users Guide" on page 19. I've extracted it from the document and pasted it below: <xsd:schema xmlns:xsd="">www.w3.org/.../XMLSchema"> <xsd:complexType name="Item"> <xsd:all> <!-- Any user elements defined by the ItemType for the item --> <xsd:complexType name="Relationships" minOccurs="0" maxOccurs="1"> <xsd:all> <xsd:element name="Item" minOccurs="0" maxOccurs="unbounded"> <xsd:complexType> <xsd:all> <!-- Any user elements defined by the ItemType for the item --> <xsd:attribute name="id" type="xsd:ID" /> <xsd:attribute name="type" type="xsd:string" /> <xsd:attribute name="typeID" type="xsd:IDREF" /> <xsd:attribute name="action" type="xsd:string" /> <xsd:attribute name="sort_order" type="xsd:integer" /> </xsd:all> </xsd:complexType> </xsd:element> </xsd:all> </xsd:complexType> </xsd:all> <xsd:attribute name="id" type="xsd:ID" /> <xsd:attribute name="type" type="xsd:string" /> <xsd:attribute name="typeID" type="xsd:IDREF" /> <xsd:attribute name="action" type="xsd:string" /> <xsd:attribute name="select" type="xsd:string" /> <xsd:attribute name="order_by" type="xsd:integer" /> <xsd:union> <xsd:attributeGroup> <xsd:attribute name="pagesize" type="xsd:integer" /> <xsd:attribute name="page" type="xsd:integer" /> </xsd:attributeGroup> <xsd:attributeGroup> <xsd:attribute name="levels" type="xsd:integer" /> <xsd:attribute name="config_path" type="xsd:string" /> </xsd:attributeGroup> </xsd:union> </xsd:complexType> </xsd:schema>
Reply
  • Former Member
    Former Member
Children
No Data
