<AML>
<Item type="Method" id="6FBCE5A606B44A25AD805C1418B88388" action="add">
<comments>Admin action to search for an ID in all ItemTypes</comments>
<execution_allowed_to keyed_name="Administrators" type="Identity">2618D6F5A90949BAA7E920D1B04C7EE1</execution_allowed_to>
<method_code><![CDATA[var inn = this.getInnovator();
// Validate input
var searchId = this.getProperty("search_id");
if (searchId == null)
return inn.newError("Please provide a search_id");
if (searchId.Length != 32)
return inn.newError("search_id needs to be 32 characters.");
// Search all available ItemTypes
var searchForItemTypes = inn.newItem("ItemType", "get");
searchForItemTypes.setAttribute("select", "name,instance_data");
searchForItemTypes.setAttribute("where", "implementation_type='table'"); // ignore polymorphic and federated ItemTypes
var allItemTypes = searchForItemTypes.apply();
// In every ItemType, search for the given ID
for (int i = 0; i < allItemTypes.getItemCount(); i++)
var itemType = allItemTypes.getItemByIndex(i);
var itemTypeName = itemType.getProperty("name");
var tableName = itemType.getProperty("instance_data");
// Search via SQL to avoid any permission problems
var sql = "select keyed_name from [" + tableName + "] where id='" + searchId + "'";
var res = inn.applySQL(sql);
// If one item is found, return the result.
if (res.getItemCount() > 0)
res.setAttribute("type", itemTypeName);
return res;
// No ID found, return error message
return inn.newError("ID " + searchId + " not found!");]]></method_code>
<method_type>C#</method_type>
<name>s_find_element_by_id_server</name>
</AML>
Client-side method:
<AML>
<Item type="Method" id="7CF952DCB88F4EC5A2376E320AFDD05E" action="add">
<comments>Admin action to search for a given ID in any ItemType</comments>
// Ask the user for an ID
top.aras.prompt("Please enter ID:", "").then(
// Callback function after the prompt
function (search_id) {
if (search_id===undefined) {
// User canceled the dialog
} else {
// Check server for ID
var r = inn.applyMethod("s_find_element_by_id_server","<search_id>" + search_id + "</search_id>");
// If server returned an error, show error to user
if (r.isError()) {
top.aras.AlertError(r.getErrorString());
} else {
// If server found an item, show the ItemType and Keyed name of the item,
// and ask user if he wants to see the form of the item
if (top.aras.confirm("Search for ID: " + search_id + "\n\n" +
"ItemType: " + r.getType() +"\n" +
"Keyed name: " + r.getProperty("keyed_name") + "\n\n"+
"Do you want to open the form of the item?")) {
// open form of item, if requested
top.aras.uiShowItem(r.getType(), search_id);
]]></method_code>
<method_type>JavaScript</method_type>
<name>s_find_element_by_id_client</name>
</AML>
Action:
<AML>
<Item type="Action" id="BAFCB980FF014963B7A6D394774F0D08" action="add">
<item_query />
<label xml:lang="en">Find Element By ID</label>
<location>client</location>
<method keyed_name="s_find_element_by_id_client" type="Method">
<Item type="Method" action="get" select="id">
</method>
<target>none</target>
<type>generic</type>
<name>s_find_element_by_id</name>
</AML>
