Import BOM in Excel file to ARAS
Hi all,
I'm new to ARAS innovator and I'm not sure on how to import BOM in Excel file to ARAS. I have read from forum and they ask to use Batch Loader but I don't know how to do it. Can anyone explain step by step on how to do this.
Thanks.
Izzul
  • I know this is a relatively old post, but I am wondering how to go about adding a document instead of adding a BOM
  • Hello,
    The concept would be exactly the same, but you'd change the first line of the AML query to add documents instead of Parts. i.e.
    <Item action='add' type='Part'>
    becomes
    <Item action='add' type='Document'>
    You'd also need to update the properties to use the property names on the Document ItemType. I'd recommend checking out our blog that covers the general structure of an AML query. All items in Aras obey the same basic structure, so once you know the foundations of how to build an AML query, you can apply the same techniques to any ItemType.
  • Hi pmateo
    As Chris suggested, request you to go through the AML blog to get some idea. Below AML will be useful to add Part, Document and Part Document Relationship
    <AML>
    <item_number>ParentPart</item_number>
    <item_number>DocumentItem</item_number>
    <Item action='add' type='Part Document'>
    <source_id><Item type='Part' action='get'><item_number>ParentPart</item_number></Item></source_id>
    <related_id><Item type='Part' action='get'><item_number>DocumentItem</item_number></Item></related_id>
    </AML>
    Gopikrishnan
  • Thanks! I read the material that Chris sent, then used the following script:
    <source_id><Item type='Part' action='get'><item_number>@1</item_number></Item></source_id>
    <related_id><Item type='Document' action='get'><item_number>@2</item_number></Item></related_id>
    Worked like a charm!
  • Based on your use of @1 and @2, it seems like you're writing a AML to use with the Batchloader. In that case, it makes sense to add the relationship item and directly set the source_id like you're currently doing. However, for other scenarios I want to propose an alternative way to structure this kind of AML. The query below adds relationships directly in the context of the parent item which will automatically set the source_id property for you.
    <AML>
      <Item type="Part" action="add">
        <item_number>Parent Part</item_number>
        <Relationships>
          <Item type="Part Document" action="add">
            <related_id>
              <Item type="Document" action="add">
                <item_number>Document Item</item_number>
            </related_id>
        </Relationships>
    </AML>
    If you're ever dynamically creating queries inside of a Method, I've found using this structure is easier to understand and helps make the Method more maintainable.
